Looking for a diesel fuel cap for my 77 Power Wagon
Postby Collers9640 » Thu Dec 28, 2017 6:40 pm
I’m trying to find a fuel cap that breaths for my 77 Cummins that looks stock. Anyone has any suggestions or maybe something I can do to mod a fuel cap?
Collers9640
Re: Looking for a diesel fuel cap for my 77 Power Wagon
Postby thrashingcows » Thu Jan 04, 2018 8:10 pm
Guess you don't want a green one? I bought one of those, green with "diesel" written on it. I am paranoid that some clown might try and fuel the truck and not notice that it's diesel. ;)
thrashingcows
Postby Collers9640 » Fri Jan 12, 2018 6:05 pm
Yep I don’t take no chances either I have a locking green slant cap on my 91.5 but the 72- 80 dodge truck don’t have a screw in fuel cap
Collers9640
Postby PToombs » Fri Jan 12, 2018 6:34 pm
Is the filler in the cab corner? It takes the cap with tabs right? Take the neck out and put in a newer neck with threads. You can modify it if you have to, cut and reweld to make it straight, or change the curve.
Postby thrashingcows » Wed Jan 17, 2018 3:04 pm
PToombs wrote:Is the filler in the cab corner? It takes the cap with tabs right? Take the neck out and put in a newer neck with threads. You can modify it if you have to, cut and reweld to make it straight, or change the curve.
Was just going to type out this very same response.... ;)
thrashingcows
Postby Collers9640 » Mon Feb 12, 2018 7:29 pm
The Filler Neck I’m on the bad. I don’t want to put a newer treaded cap on... it just wouldnt look right.
I know I 1978 dodge put a diesel in their pickup, I wish I could figure what they used
Collers9640
Postby 79Powerwagon » Tue Feb 13, 2018 6:04 am
Probably a breather on the tank
79Powerwagon
Postby bensol64 » Mon Oct 21, 2019 11:28 pm
You can find replacement caps on rockauto.
bensol64
