Project sleeper
Project sleeper
Postby NYCEGUY01 » Thu Feb 28, 2008 8:02 am
I am just starting a little cruiser project and have a couple of questions.
The truck is going to be a 92 stsndard cab dodge shortbed completely stock looking from the outside right down to the dogdish hubcaps and Ram 150 emblems.. Inside will have a 600hp p-pump motor.
Im starting with a 92 250 cummins truck that Im going to shorten and put on a shortbox so most of what I need is allready there. Im trying to make this go easier. lol
Not really a full on conversion but I figured Id post here as dodge never built a 2wd shortbed diesel.
The 1st question is how will the 1st gen truck accept a 95 p-pump motor ??
I know it will bolt in but what do I have to look forward to trying to get the tranny to shift( The tps wont bolt onto the p-pump like it did on the ve)
Is there a tps off a newer truck I can splice in ???
Anything else I should know before I get the tools out and start swapping ???
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
Postby cummins king » Thu Feb 28, 2008 1:41 pm
your going to need a bigger exhaust, because that gasser exhuast pipe ant going to cut it, lol
93 4X4 auto
cummins king
Postby cummins king » Thu Feb 28, 2008 1:43 pm
93 4X4 auto
cummins king
Postby NYCEGUY01 » Thu Feb 28, 2008 2:05 pm
What gasser ??
NYCEGUY01
Postby oldestof11 » Thu Feb 28, 2008 3:12 pm
For 600 hp, get a 47RH. It will hold better than the A518 and have a OD over the 727. Plus it has lockup.
Got $$$ and time? I have everything to complete my mess, just need time and warmer weather.
Is it going to be a DD or a drag truck? If drag, gut it now and make a custom lightweight dash, roll bars, big brakes, 4 link rear, etc. If a DD, just swap adn go.
HTH,
Postby cummins king » Thu Feb 28, 2008 3:56 pm
NYCEGUY01 wrote:What gasser ??
you said that you were going to put 150 emblems on it
great idea though
93 4X4 auto
cummins king
Postby ford69557ci » Fri Feb 29, 2008 6:16 pm
to drop a complete p pumper all you gotta do is swap mounts and bh adapters. I would got witha a 47 or 48 series trans for a drag truck. they hold alot more power and have lockup. this sounds like a cool project
ford69557ci
Postby NYCEGUY01 » Fri Feb 29, 2008 6:41 pm
What about the wiring etc ???
I know the p-pump doesnt have that little tps mounted on top of the pump.
Just looking for all the little differences before I get to swapping
NYCEGUY01
Postby Rug_Trucker » Wed Jul 02, 2008 12:10 am
I was hoping to see a 4 door with a 108" "high rise" sleeper. :( :(
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Users browsing this forum: No registered users and 76 guests
