1st gen in a 94 silverado heavy 1500
Postby proeliator » Mon Aug 04, 2008 8:44 pm
Well guys I am new here and am new to dodge/but today is day 2 of my install. I have spent 6 months collecting the parts I wanted. Motor tranie Tcase are all in now working on mounts. I will be seeking help on some electrial, also going to have some cooling issues...
Mike
proeliator
Postby proeliator » Mon Aug 04, 2008 8:57 pm
So First of many questions....will my factory in tank fuel pump be enough of a lift pump? factory was a tbi 350.
proeliator
Postby jwrkansas » Thu Aug 07, 2008 12:05 pm
Well, i have also converted a 92 tbi truck to a 91 5.9. I am using the electric pump and i also have the factory lift pump on the engine. It seems to run ok right now. We'll see what happens when i get it on the road. I dont think it has too much pressure though, somewhere around 15psi.
92 chevy 4x4 91 non intercooled engine nv4500 valair clutch, full fuel screw turned 2 turns, slightly ground fuel cone, 366 spring, stock baby h1c , stock lift pump, timing to head and autometer ultralite boost and pyro. 17 second race truck!!
jwrkansas
Postby GO OVRIT » Thu Aug 07, 2008 9:29 pm
If you're going to run both the electric and the mechanical, you might want to switch to a piston lift pump. 15 psi going in to a diaphram pump could fill the crankcase pretty quick should the diaphram go bad.
GO OVRIT
