1951 GMC w/ 1989 6BT
Postby 75Dodge » Thu Oct 09, 2008 2:00 pm
So I came upon a real deal with a 1951 GMC pickup. I was on it's way being restored and the owner lost interest. It is riding on a 1971 Chevy 1/2 ton chassis. Came with a couple of 4-bolt 350's and a freshly rebuilt 700R4.
I was wondering what anyone thinks about doing this. I understand that the 6bt is significantly heavier than the original I-6, but they are roughly the same dimensions.
My reasons for using a 6BT is that I would basically be butchering my d-250 for the powertrain and I wouldn't have to buy a new engine. But I would swap in a 5-speed manual.
Do you think I would be better off with a 4BT?
I want it to be diesel powered.
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby oldestof11 » Thu Oct 09, 2008 3:32 pm
After working in my Suburban (not finished) I wish I had a 4bt. Smaller and more easily adaptable to a Chevy. Reason? They came with Turbo 400's and motor adapters! But you do what YOU want.
The difference between the 1/2, 3/4, and 1 ton is the number of cross members and front suspension from what I am told....
Postby 75Dodge » Fri Oct 10, 2008 6:15 pm
Yeah that was what I was thinking. Easier to package, lighter weight, don't need to make as many modifications...
How far along is your conversion?
75Dodge
