'93 Fummins
'93 Fummins
Postby 93_Fummins » Wed Apr 08, 2009 5:28 pm
I figured it would only be appropriate to post and let it be known that there is a new Ford guy corrupting the site. Here are some pictures of my franken-ford creation with 1st Gen Cummins Power!
Everything was handmade by my dad and myself...BUILT NOT BOUGHT!!!
93_Fummins
Postby crewcabxlt » Thu Apr 16, 2009 11:24 am
very nice, I,ve done a couple of 70,s fords.cummins power makes for a great truck.
crewcabxlt
Postby Ace » Thu Apr 16, 2009 7:25 pm
Wow, I've never seen rear blocks that high before. I couldn't see any traction bars either. It must pull enough axle wrap to buck like a wild bull starting out hard in 2wd on dry pavement.
Ace
Postby 93_Fummins » Fri Apr 17, 2009 6:53 am
Ace wrote:Wow, I've never seen rear blocks that high before. I couldn't see any traction bars either. It must pull enough axle wrap to buck like a wild bull starting out hard in 2wd on dry pavement.
The pictures were taken before the traction bars were built. I got antsy and couldn't help taking it for a little joy ride before it was finished :oops:
Yeah, the blocks are waaaaay bigger than I would like. They are 9". It's a budget build, unfortunately, and I couldn't afford new rear leaf packs...
93_Fummins
Postby 93_Fummins » Mon Jun 22, 2009 7:12 am
UPDATE!!!
Here are some pictures of the Fummins as of late.
The bumper and traction bars (which you can't see very well) were both hand made by myself.
93_Fummins
Postby CE_TX » Mon Jun 22, 2009 8:11 am
Nice job on the front bumper and the truck looks good!!
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Postby SNOOT » Mon Jun 22, 2009 9:09 am
That thing is sweet!
1993 W350
SNOOT
Postby redneckroot » Mon Jun 22, 2009 10:40 am
Do you have any pics of your rear drive shaft hoops? It looks like something interesting going on there.
redneckroot
Postby 93_Fummins » Mon Jun 22, 2009 11:00 am
redneckroot wrote:Do you have any pics of your rear drive shaft hoops? It looks like something interesting going on there.
No hoops. The traction bars are latticed like old school bridge beams. I'll get some more technical pictures as soon as I can.
93_Fummins
Postby 93_Fummins » Mon Jun 29, 2009 10:38 am
Here are some pictures of the traction bars. As soon as money permits, I'm going to try to get some rear lift springs and reduce the block height to less than 6 inches, ideally. I also finished wiring the cab lights...all 7 of them. :grin:
93_Fummins
Postby PToombs » Mon Jun 29, 2009 5:51 pm
You should straighten your axle vent hose. The loop is not a good thing. If it gets moisture or oil in it, it won't actually vent. It will act like a thermometer with the fluid going back and forth, and no air getting thru.
Postby 93_Fummins » Tue Jun 30, 2009 6:59 am
PToombs wrote:You should straighten your axle vent hose. The loop is not a good thing. If it gets moisture or oil in it, it won't actually vent. It will act like a thermometer with the fluid going back and forth, and no air getting thru.
True. The picture is decieving though. It's actually sitting well enough to not create a trough for moisture to sit, but the picture makes it look like it's pig tailed. Good point though.
93_Fummins
Postby 93_Fummins » Tue Nov 17, 2009 3:47 pm
Unfortunately my days of enjoying the glory of a 1st Gen Cummins are over...for now. I've decided to join the dark side and join the p7100 forces of evil after the thermal meltdown of my VE mill.
I'll still be popping in from time to time, but my VE BOMBing days are no more... I just want to thank all the great minds who offer their priceless advice on this forum. I've learned so much about this amazing motor and I'll miss the tuning simplicity of the VE pump.
Thanks again guys! But, it's time for me to join the "easy 500hp" club.
93_Fummins
Postby 1STGENFARMBOY » Tue Nov 17, 2009 3:53 pm
Thats OK P-pump you know who your father is. :D
Re: '93 Fummins
Postby artieb » Thu Aug 26, 2010 5:38 pm
It was the Ford blue valve covers.....
93 CC CTD auto 4x4 plow truck, 01 Fummins with 92 CTD, ZF-6 in northern Indiana AND a VE pumped 1.6 TD 1986 Samurai
artieb
