93 Bus motor
93 Bus motor
Postby mrsemi05 » Sun Dec 06, 2009 5:16 pm
hey i was on ebay the other day and found a Bluebird bus with a 6BT cummins in it with 87k on the motor and trans and im tryin to find out it the motor will fit in my chevy truck cause i bid on it for giggles and i got the winning bid and i want to know if this thing will work for my swap or not???
thanks Tim
mrsemi05
Postby PToombs » Sun Dec 06, 2009 5:58 pm
Yeah, why not? It's the same engine that's in our trucks. You just need an adapter or change the trans. I'm sure you've already been thinking about that if you bought the engine. ;)
Postby mrsemi05 » Sun Dec 06, 2009 8:06 pm
well so far im winning it and dose it have the same bolt pattern as the dodge or will it have a diffrent one????
mrsemi05
Postby PToombs » Mon Dec 07, 2009 6:37 pm
The pattern is on the block. There is an adapter plate that bolts to the block. The plate on the bus probably won't be the same as a dodge. I think they are rated by number, SAE #1, #2, #3, etc. I'm not sure what number the dodge plate is, or if it seperate.
Users browsing this forum: No registered users and 76 guests
