new project
new project
Postby lectro_static » Sun Dec 05, 2010 5:38 pm
Bought a 1985 chvey crew cab, $300 no motor/tranny or wiring interior is out but has it all and best of all NO RUST/ROT. Big project but worthwhile I think, some bigger problems I can see will be hydraulics for the clutch and 2wd to 4wd swap.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: new project
Postby lectro_static » Tue Dec 07, 2010 1:16 pm
Truck is at my shop now, pretty torn down and will get painted as I go but here are a few more pictures. I do have a couple questions, on a 93 dodge the fuel kill is keyed hot, so I could just use the "coil wire" from the new harness? What does the KSB do? It is not hooked up on my truck now but would like to be able to hook it up if needed.
Sorry for the crappy pictures they are cell phone pics.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby Richie O » Tue Dec 07, 2010 1:25 pm
Non rust belt. :mad: Must be nice. :roll:
Re: new project
Postby RumbleFish » Tue Dec 07, 2010 2:14 pm
that veedub sure looks like fun!
Re: new project
Postby lectro_static » Tue Dec 07, 2010 2:40 pm
RumbleFish wrote:that veedub sure looks like fun!
If I can get it finished it will be, 2.3 turbo ford motor, 35" rear tires and 31" front about 20" of travel on all 4. Might sell it to fund this crew and build a manx instead havent made my mind up about that yet
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby ellis93 » Tue Dec 07, 2010 2:59 pm
Might try to find a 86 or 87 chevy in a junk yard. If it was a standard, it had a hydro clutch. I've seen a couple of 4X4 trucks around here with them.
Re: new project
Postby lectro_static » Tue Dec 07, 2010 4:07 pm
ellis93 wrote:Might try to find a 86 or 87 chevy in a junk yard. If it was a standard, it had a hydro clutch. I've seen a couple of 4X4 trucks around here with them.
Yup Im on the hunt for the pedal set and hydros but I think the bore size may be to small for the getrag slave, need to look into that. I am thinking of yanking the slave off my dodge and using it just adapt it over to the chevy hole.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby PToombs » Tue Dec 07, 2010 5:57 pm
To answer your questions and not get side tracked by the beetle...... :lol: Yes, you can use any keyed hot for the fuel shut off solenoid. And the KSB is the cold start advance. The sensor should be on the rear of the intake. Key on, cold temp activates the switch, and it advances the timing 7* and bumps case pressure so it starts better and smokes less when cold. You can put it on a switch, but then there is a good chance of popping the seals in the pump if you forget to shut it off. Don't ask how I know. :oops:
Re: new project
Postby 1STGENFARMBOY » Wed Dec 08, 2010 7:19 am
Hey you need another project, :lol: :lol:
Dar
Re: new project
Postby lectro_static » Wed Dec 08, 2010 8:56 am
1STGENFARMBOY wrote:Hey you need another project, :lol: :lol:
Dar
Like a hole in my head.......... but I just couldnt pass on this truck. I want a crew cab and cant afford a newer truck so here we go.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby 1STGENFARMBOY » Wed Dec 08, 2010 1:30 pm
Well theres no way a guy could pass that up.....NO WAY
Dar
Re: new project
Postby lectro_static » Wed Dec 08, 2010 2:16 pm
1STGENFARMBOY wrote:Well theres no way a guy could pass that up.....NO WAY
Dar
agreed and thats what gets me into trouble every time :D
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby PToombs » Wed Dec 08, 2010 7:04 pm
If I had money available I'd get into a lot more trouble than I do. It's not fun being broke, but it's safe! ;)
Re: new project
Postby lectro_static » Wed Dec 08, 2010 10:52 pm
Thats part of my problem Pete I AM broke, got this truck instead of a bend die that I need but a deal is a deal
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: new project
Postby ellis93 » Fri Dec 10, 2010 7:36 am
Signed up over at 4BT swap and was lookin for the chevy adapters and found this.
http://www.4btswaps.com/forum/showthrea ... lic-pedals
