4 doors - let's build one more...
Postby draginmopars » Thu Jan 20, 2011 9:08 pm
we just got a 92 club cab with 618 going in a 74 car hauler.
should we cut the cab at the "A" post and mid floor or
cut out the fire wall and patch in?
also, should we cut the frame and keep the 92 front-end or swap it to the 74 frame?
at the rear I think, we will need a diesel rear vs the gas rear that is there now?
found a 3.55, would that be the gear needed with the OD?
was looking at it cause it has the anti-lock hook-up
any ideas?
thanks
Gayle and howard
Last edited by draginmopars on Thu Jan 20, 2011 11:35 pm, edited 4 times in total.
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Re: 4 doors -n- more
Postby draginmopars » Thu Jan 20, 2011 9:28 pm
yea, we both blonde lol
changed our minds, gas prices going up helped
plugs didnot help.. lol
even with the 440/ od we figured the cummins would be better
Last edited by draginmopars on Thu Jan 20, 2011 11:37 pm, edited 2 times in total.
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Re: 4 doors - let's build one more...
Postby lugnutz » Thu Jan 20, 2011 10:30 pm
Nice Max wedge manifolds...they look right at home in a big ole truck.
Whats the story behind the O.D trans on the big block? Is there an adapter involved or did something get machined?
1998 Freightliner FL70 Crewcab, Cummins 8.3
Sold :-( 1992 W350 Clubcab, Getrag
BHAF, Stans 4" exhaust, H1C, GDS 60mm, 16cm housing, tweaked pump, Kdp, Autometer guage package.
lugnutz
Postby draginmopars » Thu Jan 20, 2011 11:01 pm
JW bell, machined off the factory one
I have done 6 like this.
this one is in the rampage with a 727- 5000stall
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Fri Jan 21, 2011 3:27 pm
this is what we have to work with, getting ready to pull the bed and doors/carpet. front clip.
still haven't decided to chop the cab or swap the fire wall
going to use the 74 ramp truck doors and fenders, grill
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby PToombs » Fri Jan 21, 2011 7:02 pm
I would cut the firewall and piece in the section you need. I'm not sure how different the 74 is from the 92. I put an 86 cab on my 92, and just cut out the clutch area of the firewall. (86 was auto and 92 a 5 speed) The bulkhead plug was right where the clutch master came thru. I just cut about a 1' x1' piece from the 92 and fitted it in. Tied in the steering column brace too, I put the seam right on it so I could weld it together.
Do yourself a favor and leave the ABS on the donor truck. Most of the time it doesn't work correctly and causes a spongy brake pedal.
Postby draginmopars » Mon Feb 07, 2011 1:23 am
got a little time to work on it.
think i,m going to section the rad support for the 73 head lights/ turn signals
instead of moving the brackets for the rad, i/c, and a/c..
also gonna use the p/w,and door locks,
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Mon Feb 07, 2011 1:35 am
our next plans are
pyro and boost guages
trans temp
tighter torque convertor
freshen trans
replace crank seals/ pan gasket
adjust valves, bump the timing
have a leak at the p/s pump need fixed
replace all hoses and belt
core plugs
is there a part # for the elbow water hoses?
Do I really need a tach.
What else need done, while eng and trans are out.
thanks
gayle and howard
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby PToombs » Mon Feb 07, 2011 6:49 pm
Check the KDP and tab that, and remove, clean, loctite the case to block bolts. Easier to do on the stand than in the truck. ;)
Postby draginmopars » Thu Mar 24, 2011 5:58 pm
what have I gotten myself into lol
got the donor, stripped down to the last wire harness
and cross members,fuel lines
gonna get rid of the in cab fuel tank.
the OD trans cross member is different from the gas engine and the turbo exhaust pipe won,t clear
needs to move back again for the diesel
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Thu Mar 24, 2011 6:04 pm
since the truck was wrecked when i got it
i need a grill etc.
so i modded the 73 into the 93
feels like I'm moving forward now
next is the cab mods
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Wed Jun 29, 2011 1:45 am
sanding my days away
got the cab welded back together 73 / 92
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Wed Jun 29, 2011 5:41 am
It's looking good.
Postby 1arock » Sun Jul 24, 2011 6:23 pm
Al that welding and cypherin looks familiar. Nice work looks good.
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby dazedandconfused » Sun Jul 24, 2011 6:29 pm
Have you made anymore progress on it?
