2wd to 4x4 swap
2wd to 4x4 swap
Postby lukescummins » Fri Feb 18, 2011 6:50 pm
ok so im 17 and want to make my truck 4x4 cant afford a new truck but i can take the time to buy all the parts i need to do the swap.(even if it costs more moneyin the long run) If things go right i would like to do it this summer. if anyone has pic of there swaps, cheap parts, or would be willing to help me complete the swap that would be great.
lukescummins
Re: 2wd to 4x4 swap
Postby 1stgenblowingsmoke » Sat May 28, 2011 6:35 pm
I can't give prices, pictures or help you work on it but I can tell you it has been done before n I think all you need to do to the frame if I remember right is add the rear shackle hangers.
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Re: 2wd to 4x4 swap
Postby BobS » Sun May 29, 2011 3:04 am
I'm doing a 2WD to 4WD conversion on an older crew cab truck. The ONLY reason I'm doing it is because there are/were no available 4WD crew cab frames local to me. You might be farther ahead time and dollar wise to just find a good used 4WD frame with springs and build off of it. There are quite a few getting scrapped because the trucks are getting parted out for their major components.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
