2003 Cummins Injector Rebuild
All of 'em
Postby collegekid » Fri Nov 04, 2011 6:41 pm
What all is involved with rebuilding 3rd gen injectors, or for that matter, any injector....are the rebuild kits expensive? Are special tools required?
collegekid
Re: 2003 Cummins Injector Rebuild
Postby KTA » Sat Nov 05, 2011 6:58 am
3rd gen injectors require a $25000 test stand to test. Since you can't pop test one there is no way to verify the spray pattern or chatter and seating. All you can do is swap tips on one with no way to know what the result was.
Postby collegekid » Sat Nov 05, 2011 7:25 am
oh wow, ok, well scratch that idea....thanks
collegekid
Return to Other diesels
