jd 410 engine stuck
All of 'em
jd 410 engine stuck
Postby txs » Sat Mar 24, 2012 6:25 am
The motor on my 410 diesel is stuck, should i pull the head or pull the injectors and pour something into the cylinders and let it soak? I believe it's a jd motor.
txs
Re: jd 410 engine stuck
Postby ellis93 » Sat Mar 24, 2012 7:28 am
I'd soak it. Dad had used trans fluid at one time.
Postby bmoeller » Sat Mar 24, 2012 7:54 am
Yep! It's a Deere diesel. :)
Pull fuel injection nozzles and put Coke or Pepsi down the holes for overnight. The citric acid in it will break the rings loose.
Works for getting aluminum wheels off too.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby txs » Sat Mar 24, 2012 4:37 pm
Are there any special tools needed or do the injects come out fairly easy?
txs
Postby bmoeller » Tue May 01, 2012 8:03 pm
As long as there isn't too much carbon on the tips, they don't come out too bad, usually.
Spray some PB Blaster on them, and hopefully some of it will wick its way down along the bodies. May need to twist them back and forth and work them out.
bmoeller
Return to Other diesels
