Need advice
All of 'em
Need advice
Postby 89workhorse » Wed Apr 18, 2012 4:59 pm
My 01 duramax is blowing alot of white smoke at idle it cleans up as u drive or if i give more rpms, im assuming an injector is sticking, is there anything i can do to quickly fix it i have a 2000,mile drive home friday or would anybody trust to drive it that way
1989 D250 4wd, Maxed ve, denny t stage 2, 366 spring, 60mm turbo upgrade, 4" straight pipe, ddp stage 3 injectors, glow shift guages, 180xxx miles
2001 2500HD 2wd, all stock (not for long) lb7 6.6 duramax, 230xxx miles
89workhorse
Re: Need advice
Postby ellis93 » Wed Apr 18, 2012 5:08 pm
If it cleans up I'd run it home. I'd also put some kind of additive in the fuel,I'd more than likely dump it some Lucas.
Re: Need advice
Postby dazedandconfused » Wed Apr 18, 2012 5:15 pm
Check your oil you should be able to tell if you have an injector hanging open by either having too much oil or by dropping oil on a clean white towel. The oil and fuel will separate on the towel. Id change the oil, fuel filter and dump a couple quarts of new trans fluid in the tank and top it off. If its just starting to stick it should get uou back home.
Re: Need advice
Postby 89workhorse » Wed Apr 18, 2012 10:18 pm
Thanks guys
89workhorse
Return to Other diesels
