4bt knock knock knock
All of 'em
Postby m880cummins » Fri Dec 07, 2012 11:53 pm
:bom: ?
Got it running tonight. Oil system was primed, ran like a champ until I builded some boost for the second time at the end. It has a 3200 rpm spring, pump screws turned, ground pin, WH1C. Also, how bout the smoke coming from the breather?!?!
First crank with a stutter:
Running:
Bent pushrod?
SUNY Maritime Class of 2017!
m880cummins
Re: 4bt knock knock knock
Postby BobS » Sat Dec 08, 2012 4:58 am
Where was your temporary cooling system? You should NEVER run a 4BT for more than 30 seconds without a cooling system of some kind in place. Then it should be allowed to cool down and equalize temperatures between the block and head. My guesses would be you possibly blew the head gasket, possibly warped or cracked the head, or scored/melted a piston and cylinder, probably #4. You were correct that it ran fine and was a good engine in the beginning of your video.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Mark Nixon » Mon Dec 10, 2012 10:35 am
Yep, cooked 'er good!
Count on a headgasket and fresh scored cylinder walls and galled pistons.
Bang up job there Gomer!
Postby m880cummins » Mon Dec 10, 2012 8:01 pm
The previous owner had the oil pump break and he shut it down. I put a new pump in, primed it and then mounted a mechanical oil pressure gauge. It put out 10 psi cranking... Old oil pump broke by the idler gear. We managed to pick out all the pieces without dropping the pan. No shavings or anything and all gears were nice. Thought we were lucky. Guess not.
Charlie
m880cummins
Postby Diesel » Fri Dec 21, 2012 6:30 pm
m880cummins wrote:The previous owner had the oil pump break and he shut it down. I put a new pump in, primed it and then mounted a mechanical oil pressure gauge. It put out 10 psi cranking... Old oil pump broke by the idler gear. We managed to pick out all the pieces without dropping the pan. No shavings or anything and all gears were nice. Thought we were lucky. Guess not.
Charlie
What you have there doesn't sound like the effect of a previously damaged oil pump. Liquid cooled engines are not air cooled engines.
1991.5 D250 Intercooled A518
Diesel
Postby PToombs » Sun Jan 27, 2013 6:09 pm
Charlie, did you ever tear into this and see what happened? Get it running again?
Return to Other diesels
