7.3 idi turn up
All of 'em
7.3 idi turn up
Postby 1992gen1_fan » Thu Aug 15, 2013 7:25 pm
Hello, can turning up a 7.3 idi (1989 model) cause runaway like the VE's in our trucks?
1992gen1_fan
Re: 7.3 idi turn up
Postby Flat bed cummins » Mon Sep 02, 2013 11:01 pm
Yes I'm pretty sure it can, rule of them I use is always think they can, I think even the old school vw diesels can run away
Flat bed cummins
Re: 7.3 idi turn up
Postby dazedandconfused » Tue Sep 03, 2013 7:07 am
Yes they will runaway. More then a 1/4 turn on the pump is useless unless its turbocharged. They just smoke and melt down otherwise.
Re: 7.3 idi turn up
Postby 1992gen1_fan » Wed Sep 04, 2013 7:57 pm
Ok thanks for the info. Its a friends truck, he was wanting to know if I'd turn it up just a tad. I did tell him he needs a pyro before I even think about messing with it especially being non turbo'd. I figure 1/4 turn would be good enough. Thought I'd make sure 1/4 turn would be safe (no threat of runaway), thanks :D
1992gen1_fan
Re: 7.3 idi turn up
Postby Flat bed cummins » Wed Sep 04, 2013 11:19 pm
No problem I used to have a old 6.9, one of my favorite trucks until the rings got bad.
Flat bed cummins
Return to Other diesels
