Turbo options, 6.2l diesel
All of 'em
Re: Turbo options, 6.2l diesel
Postby matthewh » Fri Nov 20, 2015 11:14 am
I'll get some up in a bit. I'm running a windows phone, and it/ I can't seem to get the image link to work from Photobucket. It won't seem to highlight the whole link, just parts.
With the turbo, I built a downpipe out of 2x4 steel tubing, due to space issues in my fender well. I'm hoping to be able to reuse some of that setup and tie my 2-1/4" exhaust into it, it will still be pass side exit, in front of the rear tire.
matthewh
Postby matthewh » Fri Nov 20, 2015 5:53 pm
Here's the air cleaner setup I built. I can still use it without the turbo, just gotta add an elbow and a reducer.
The downpipe I had to build to clear a shock, and follow the curve of the fender. Unfortunately without the turbo, this goes to the junk pile, but the 2x4 exhaust that ties into it I can use and tie my manifolds into
After today I've got a week off work, so I'm hoping to finish some little things on it and see if I can get it to run.
matthewh
Postby spencerdiesel » Fri Nov 20, 2015 6:19 pm
Yea 7.3s remind me of WRX's, going wiiiide open and you ask "you gonna nail it"?
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Fri Nov 20, 2015 6:20 pm
Nice, I need to learn how to fab stuff.....
H1C/18
Muffler delete
spencerdiesel
Return to Other diesels
