New trucks and EGT's
All of 'em
Postby spencerdiesel » Sun Dec 20, 2015 6:17 pm
On other forums, I've seen guys with factory trucks state they've seen anywhere from 1350 to 1500 plus (loaded of course)..........if this is true, what alloys are modern pistons made of?
H1C/18
Muffler delete
spencerdiesel
Re: New trucks and EGT's
Postby PToombs » Sun Dec 20, 2015 6:24 pm
Not sure what trucks you mean. I know the new dodges run a lot hotter than ours do, engine temps up to 230 or so, and EGTs hotter because of the emission crap on them.
Postby spencerdiesel » Sun Dec 20, 2015 6:26 pm
Sorry that was a little vague :lol: Commonrail dodges primarily. So what sustained temps have you heard of with them?
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Sun Dec 20, 2015 6:35 pm
IIRC about what you posted, not 1st hand from anybody in person though.
Postby spencerdiesel » Sun Dec 20, 2015 7:23 pm
O ok. Know if anyones ever tested the waters of > 1250 sustained on 12v's? I know it's stupid to risk experimentation with that but I get curious occasionally.
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Sun Dec 20, 2015 9:58 pm
By that I mean Cummins inc. tests. If something was actually deformed or melted @ 1300 or so in testing, thus the 1250 standard....?
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Sun Dec 20, 2015 10:42 pm
The new cr stuff is rated to about 1400*. I've held 1900* for bursts with my 6.7 when I still had the stock turbo. She still runs fine, but with the new chargers I've had on I don't get so hot anymore
Postby Tacoclaw » Mon Dec 21, 2015 9:17 am
I doubt they're made of any better materials, I think they just have better control of the timing. On our trucks when the EGTs are at 1200 then the cylinder temp is also at a certain temp. They're tied hand-in hand with our timing which, while variable, is still set to RPMs.
CR trucks can vary their timing to any number of variables, so even though their EGTs are 1200 their cylinder temps could be any range of temps.
Postby spencerdiesel » Mon Dec 21, 2015 6:01 pm
Thanks for the #'s Dman. That would make some major sense, I knew them computers did more than just make my brain hurt :lol:
Any 1st genners with a lot of timing still hold 1250 continuous with no issues?
Are our exh. valves sodium filled?
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Mon Dec 21, 2015 6:10 pm
They are not
Postby spencerdiesel » Mon Dec 21, 2015 6:25 pm
Thanks.
H1C/18
Muffler delete
spencerdiesel
Return to Other diesels
