Deere 7800 starts like CRAP!
All of 'em
Postby Fnschlaud4620 » Sun Mar 30, 2008 7:47 pm
Just picked up a real nice 7800, Tractor is almost mint but it is by far the WORST starting tractor on our farm!
The other day it was around 50 deg and we had to move machinery to get out the planters & spring stuff, anyway the tractor caughs and spits and shakes for like 30-40 sec before it catches its breath and runs like it should. Is this normal?
I have seen the typical full fuel rare up at startup but this is STUPID. Once it has been running and warm it is a good start but I would have thought 50 deg was warm enough?
Is there any adjustments? dont want more power just a better start.
Thanks,
Fnschlaud4620
Fnschlaud4620
Postby KTA » Sun Mar 30, 2008 9:06 pm
Check that the electric fuel pump is working, but most importantly inspect all the fuel hoses coming from the tank for any dirt or moisture on them. We have a lot of problems with that braided cloth hose seeping fuel/sucking air when it gets old. It sounds like you might have a fuel drain back issue.
Postby Fnschlaud4620 » Wed Apr 02, 2008 9:41 pm
Thanks for the help KTA, I will check it out next time I am home.
Fnschlaud4620
Return to Other diesels
