Needing some help with an N-14
All of 'em
Postby peytonmaterne » Fri Aug 28, 2009 7:55 am
Neighbor has a mid 90s White/GMC Volvo wannabe. N-14 that hasn't been started for a year. We charged the batteries and are cranking over but we have no power at the fuel shut off solenoid. We checked all the fuses in the cab. Are there any external fuses? Can we run a seperate wire to the solenoid to let it run or does the computer need to see a signal from the solenoid?
91.5, D250, getrag
91.5, D250, auto
84, D150 with 90 dodge/cummins drivetrain
peytonmaterne
Postby KTA » Fri Aug 28, 2009 8:41 am
If it is an old enough n-14 it is a mechanical and you can just put 12V to the solenoid to get it to run. If it is a later one it is electronic controlled by the computer and you will have to start there.
Postby peytonmaterne » Sat Aug 29, 2009 7:48 am
Hey KTA, it is an electronic engine. I think he said it is a 95, anywho it has the computer on the drivers side of the engine.
91.5, D250, getrag
91.5, D250, auto
peytonmaterne
Postby KTA » Sat Aug 29, 2009 10:00 am
If the ECM is receiving power but not outputting power to the pump or injectors then it won't run and most likely has a failed ecm or a bad crank position sensor. You can either hookup the cummins laptop to diag. the problem or go borrow the parts from a running unit and switch them out to find the problem. Check to make sure the ECM is getting power 1st though!
Postby skilletky » Sat Aug 29, 2009 10:48 am
check the fuse in the batt box and the wire that goes from the batts to the ecm. almost all of our old volvo vn670's had that wire rubbed through in several spots. the wire from the ecm to the fuel shut off always rubbed through and broke too.
skilletky
Postby peytonmaterne » Mon Aug 31, 2009 10:11 am
There is a red cable with a large inline fuse in the battery box, and it had rubbed almost completely through where it comes thru the hole in the battery box. The two fuses around the starter looked OK but I replaced them anyway. I will fix that cable and go from ther I guess. Thanks for the help thus far.
91.5, D250, getrag
91.5, D250, auto
peytonmaterne
Postby peytonmaterne » Wed Sep 02, 2009 10:31 am
Well, I got the cable fixed that I mentioned previously. This cable and a white one run up to the back of the head where they branch off feeding various wires. I still have no power at the shutoff solenoid. How and where do I check for power on the ecm?
91.5, D250, getrag
91.5, D250, auto
peytonmaterne
Postby skilletky » Thu Sep 03, 2009 7:47 am
i have a compleat wire diagram for the n-14's at work. i will get it tonight when i go in and post a pic of it on here or pm it to ya or something. i can not remember where to start.
skilletky
Postby peytonmaterne » Fri Sep 04, 2009 6:35 am
OK, thanks for the help. This guy was retired but had to go back on the road, I think he got a 2004 mack Vision? So I guess I can take my time on this.
91.5, D250, getrag
91.5, D250, auto
peytonmaterne
Return to Other diesels
