04 valve adjustment
All of 'em
04 valve adjustment
Postby jwatso8 » Fri Dec 18, 2009 12:12 am
my dads 04 cummins/dodge the valves rattle pretty good in the morning when its cold. does anyone know the mileage at which the valves need adjusting? i know how, just needs mileage. thanks. if it makes a differance its the 305hp 555tq engine.
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby KTA » Fri Dec 18, 2009 10:45 am
24V motors are stated to be 100,000mi between valve adjustments.
Postby jwatso8 » Fri Dec 18, 2009 4:18 pm
thanks KTA
well i guess it time to do it. his truck has 100216 miles on it now.
by the way a stupid question what does KTA stand for? and i know your going to ask about mine its my work user name. J- for john, WATSO- for watson and im the 8th watson that works there.
jwatso8
Postby dpuckett » Fri Dec 18, 2009 4:26 pm
Correct me if I'm wrong, but the KTA is probably for the KTS in his mid 70s KW that's getting like 1000-1100hp to the wheels.
The Cummins stated mileage for 24V engines is a load of horse manure. I did the valves on an 01 with ~80K several years ago, first time it had been done on that truck. Guy told me the next week it was like driving a brand new truck. I did have to tighten each adjuster about 1/4turn or so- they definitely needed doing.
Valve adjustments are like trimming horses- it cant be done too often.
Dan
Postby KTA » Fri Dec 18, 2009 9:24 pm
Yep the KTA's are the ultimate Diesel 6cyl for beef and reliability. I do have one that is dynoed over 1000hp too. Made the Cat boys upset when it shut their dyno down. :P Yes if you overlaod a big waterbrake dyno the safetys kick in and turn the load loose. I was told that was the only time it had ever happened........ and they didn't want it to happen again...... have a nice day but don't come back! lol
Return to Other diesels
