Need a little help for my friend
All of 'em
Postby SOOT4BRAINS » Tue Dec 29, 2009 9:46 pm
A buddy of mine has an 84 ford with a 6.9 international in it. It needs a new oil cooler. I have been trying to find one for him, but only one I can find is from the dealer and they want over a grand for it. Thought it couldn't hurt to post up on here and see if anybody knows where to get one. He told me it has a tube like cooler and 2 end tank pieces that attach to the engine. He really wants to do a 12 valve conversion but its not in budget and needs his truck back. Any help is appreciated. Thanks!!
Aaron
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby dpuckett » Wed Dec 30, 2009 2:31 pm
Is the problem in his cooler itself, or just the gaskets? If I'm not mistaken, the coolers were the same on all 6.9s and 7.3s, so that may open up your options.
Have you tried a Navistar dealer? Kinda like bypassing Dodge to go to Cummins.
Dan
Postby SOOT4BRAINS » Wed Dec 30, 2009 9:21 pm
I have not actually seen it yet, but he told me it was pushing oil into the antifreeze. Can it do that with just bad gaskets? I will look into a navistar dealer locally, thanks for the reply.
Aaron
SOOT4BRAINS
Postby dpuckett » Thu Dec 31, 2009 10:25 am
Yes it can be just gaskets. Anytime you have oil and antifreeze seperated within a common housing (think head gasket- it blows, and sometimes mixes oil and water) the potential exists for fluid swapping if a gasket/ seal fails.
I'd think a radiator shop would be able to pressure test the cooler once you get it out.
Postby SOOT4BRAINS » Thu Dec 31, 2009 6:52 pm
He has it out, not sure if he has tested it. Did some internet searching, I can't find a navistar dealer online. Guess I'll start calling around to truck dealers.
Aaron
SOOT4BRAINS
Postby oldestof11 » Fri Jan 01, 2010 9:30 am
Search for International truck dealers.
Return to Other diesels
