CFM+
All of 'em
CFM+
Postby jwatso8 » Wed Feb 03, 2010 2:33 am
Are any of you guy's running a CFM+ on your trucks? I got an 07 dodge, and would like better mid range (1500-2000rpm). They say its supposed to help mid range. Just wanted to see what you guy's thank if you have one on your truck? Thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby jwatso8 » Thu Feb 04, 2010 10:06 pm
Well just ordered my CFM+ from Diesel Power Products. I'll let you guy's know how i like it.
jwatso8
Postby peobryant » Fri Feb 05, 2010 2:28 pm
What's a CFM+? :scratch:
Postby PToombs » Fri Feb 05, 2010 7:18 pm
It's an over valved thing, that we don't understand. ;)
Postby jwatso8 » Fri Feb 05, 2010 10:38 pm
CFM+ is an aftermarket intake horn for 94-07 dodges. Its made out of composite material. Check it out at www.cfmplus.com
jwatso8
Re: CFM+
Postby jwatso8 » Sat Feb 20, 2010 4:02 am
well i got it put on the other day. i like it, other than its a pian to put on (used studs and the dipstick position) it looks good and sounds good too. it realy helped to pick up the performance in the mid range.
jwatso8
Return to Other diesels
