Help Diagnosing a P-Pump
All of 'em
Postby lectro_static » Fri Mar 12, 2010 2:09 pm
A buddy of mine has a 94 or 95 P-pump runs great but when he shuts it off it will idle for 3 to 10 seconds, it is getting worse so he would like to get it fixed ASAP and I really dont even know where to begin with it.
Thanks in advance
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: Help Diagnosing a P-Pump
Postby IowaCummins » Fri Mar 12, 2010 5:28 pm
Shut off solenoid getting weak and not making an abrupt fuel shut down?
IowaCummins
Postby lectro_static » Fri Mar 12, 2010 5:52 pm
kinda what I was thinking, anyway to test it or is it just replace and hope...
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby IowaCummins » Fri Mar 12, 2010 5:55 pm
if i was going to mess with it i would atleast check voltage. arent those p pumps know for the fuel shut off relay going bad? i want to say they are but not for sure
IowaCummins
Postby Richie O » Fri Mar 12, 2010 6:28 pm
I had a 97 and the linkage was rusty so the solenoid would not push it. Took it apart and freed it up. Worked good after that.
Postby PToombs » Fri Mar 12, 2010 7:11 pm
If it won't shut off it's probably not an electrical problem. No need to replace the solenoid unless it's really crusty with rust. Problem is what Rich said, needs lube. The bore of the unit is dry, pull the plunger out, clean it good, and lube with a light oil. Should work good then.
Postby soggy » Fri Mar 12, 2010 10:18 pm
What's a pee-pump???
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby PToombs » Sat Mar 13, 2010 7:36 pm
That's what pisses the fuel into the Funny Round Trucks. ;)
Return to Other diesels
