timming the I/P on a 4400 combine
All of 'em
Postby 1STGENFARMBOY » Mon Nov 01, 2010 8:32 am
can one of you guys tell me in a nut shell how to time and re-install the I/P on a 4400 combine, my co-worker
just bought one with the pump off and he had it checked out now we need to put in on. It's way to new for me
to know much about it, really i havent even laid eys on it i just wanted a little info before i went over.
Thanks Darwin
Re: timming the I/P on a 4400 combine
Postby PToombs » Mon Nov 01, 2010 5:32 pm
What engine? What pump?
If it's a cummins, just pull #1 valve cover and roll it over until the intake valve closes, then push the timing pin in when it gets to TDC. Hold the gear against the cam gear if you can so it won't jump a tooth when turning.
If it's a VE pump, it should be locked if it came from a pump shop. Just check the front of the pump, (shaft end) at about 5:00 there should be a mark, a line or arrow. The keyway will line up with this for #1. Stuff it in, bolt it up, and loosen the lock and shove in the spacer on it, and good to go.
If it's a P-Pump, on the rear outer side there's a large acorn nut, this is the lock cover. Remove it and inside there's a pin, 1 side is split, this is the lock. If it's locked, the split will be over a tab on the shaft in the pump. Same as above to TDC and install, then pull the lock pin and put it back in the opposite way, solid end in, and put the nut on.
Done!
Postby 1STGENFARMBOY » Tue Nov 02, 2010 4:53 am
We got it running yesterday, i think its the same engine as a 4020, 404 but i'm not shure,
thanks anyhow Pete.
Dar
Postby PToombs » Tue Nov 02, 2010 6:17 pm
I typed all that for nothing? :shock: You're back on the list buddy! :twisted:
Postby 1STGENFARMBOY » Wed Nov 03, 2010 8:36 am
NO DAD-GUMMIT it was not for nothing i printed off your page and filled it with my other how to papers
thank you very much, BUDDY
Postby PToombs » Wed Nov 03, 2010 5:26 pm
Wellllll, I guess I can move your name down towards the bottom of the list. ;)
Postby 1STGENFARMBOY » Wed Nov 03, 2010 8:15 pm
Thanks now i'll be able to sleep at night. :D
Postby PToombs » Thu Nov 04, 2010 5:51 pm
Oh good! You need all the beauty slep you can get! :mrgreen:
Postby bmoeller » Fri Mar 04, 2011 6:55 pm
Yes, it should be the 404 in that thing.
Timing the I/P is pretty simple.
Put the engine on TDC #1 (and make sure the gear lash is taken out of the gear train). Set the pump in the hole (only goes one way) and put the hold down nuts/bolts on it, but keep them loose enough that you can rotate the pump housing by hand. Remove the small rectangular inspection cover (2 small screws). Need to see where the timing marks are on the flywheel and set the flywheel in the correct spot BTDC that the manual calls for. IIRC, 14*BTDC on a 4010 engine and 0* on a 4020 (not sure on the combine though). Once there, rotate the pump til the timing marks in the little window are lined up. Once there, tighten the hold down nut/bolts. Reinstall the cover on the pump, and the timing is done. :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby KTA » Fri Mar 04, 2011 8:31 pm
A 4400 should have a 329 not a 404, they were saved for later 6600's.
Return to Other diesels
