Injector tester
A place to BS about tools and all that junk
Re: Injector tester
Postby ellis93 » Tue Sep 11, 2012 8:13 am
Yep I seen them several places now.
Cheapest I've found was at the hardware store in the form of washers :lol:
Re: Injector tester
Postby BC847 » Tue Sep 11, 2012 8:59 am
ellis93 wrote:Well......this is turning out to be wrong
Shit! I owe you $51 bucks. :oops:
Re: Injector tester
Postby ellis93 » Tue Sep 11, 2012 9:13 am
No sir,not at all,its all in the name of learning ;)
We will now learn just how long hardware washers will last :lol:
Re: Injector tester
Postby DodgeFreak » Tue Sep 11, 2012 9:38 am
What size were they? We have an assortment at work...if they work for ya ill try them also, I would measure but my calipers are at home for Reloading lol...
Re: Injector tester
Postby ellis93 » Tue Sep 11, 2012 9:56 am
The factory shims are measuring out at 7.3mm wide so anything around that,thickness wise I have no idea. I ran across a tread that a guy had cut some out of a sheet of shim stock 0.01 thick. He wanted that because he had read that 0.01 would increase pop pressure by 5bar. I'm keepin my eyes peeled for some now,and im also thinkin on cutting some out of rear end adjustment shims that I have. Of course nothing will happen till I have reason :lol:
Re: Injector tester
Postby dunes450r » Wed Nov 28, 2012 6:30 pm
washers might work in the short term, but i'd imagine they'd deform and slowly get thinner. considering how many cycle injectors see, i think they might wear out quick, unless you use grade 8 ones. let us know!!
dunes450r
Re: Injector tester
Postby ellis93 » Wed Nov 28, 2012 7:03 pm
dunes450r wrote:washers might work in the short term, but i'd imagine they'd deform and slowly get thinner. considering how many cycle injectors see, i think they might wear out quick, unless you use grade 8 ones. let us know!!
Will do.....just alittle longer and im gonna pull them to test them.
Return to Shop
