Best air hammer
A place to BS about tools and all that junk
Re: Best air hammer
Postby RCCUMMINS89 » Fri Mar 21, 2014 11:20 pm
Yep... that's what I ended up doing today.
Re: Best air hammer
Postby PToombs » Sat Mar 22, 2014 4:29 pm
It's pretty fast if you don't mind the black smelly smoke and the sticky gooey rubber on your gloves when you're done. ;)
Re: Best air hammer
Postby Begle1 » Tue Aug 19, 2014 9:55 am
In my experience the best hammer is the one with a really good air supply behind it.
The strength any air hammer hits is just a function of its piston size, stroke and the air your feeding it, right?
More pressure and any hammer will hit harder; it's just a question of whether it will last at those pressures. How is a Snap-On going to actually hit harder than a Harbor Freight if it's the same size and has the same air pressure?
But it takes a hell of a compressor to run an air hammer for more than a minute or so at 120 PSI.
Return to Shop
