6"-7"-9" angle grinder
A place to BS about tools and all that junk
Postby bgilbert » Mon May 25, 2015 11:11 am
I think I might be in the market for a larger than my current 4 1/2" angle grinder. I would be using it mostly with a cut-off wheel. Anyone have any luck with Harbor Freight 7-9" grinders? I use the chit out of my HF 4 1/2" grinders. If they go bad, pitch it, go spend $20 for a new one. I'm also considering a Milwaukee unit. I have a number of Milwaukee electric tools. I'm basically trying to pick between a Milwaukee unit or Harbor Freight unit.. Any thoughts?
Bill Gilbert
bgilbert
Re: 6"-7"-9" angle grinder
Postby ellis93 » Mon May 25, 2015 11:18 am
I have a 7" Milwaukee side grinder with the soft start.....kickass grinder. No where near as violent as the old school B&D I have of my dads. It's dubed the "man killer". I've actually rode that B&D grinder inside a truck bed with a cup brush attached.
I don't know if I'd want to use either one with a cut off wheel tho. What about a chop saw?
Postby bgilbert » Mon May 25, 2015 11:34 am
Well, I'm working on a 3' square of 1" plate that I'm trying to cut up into ~7"x16" blocks to use as press plates on my new 50 ton press. I made one 3' cut last night, took 2 hours, smoked 1 HF 4.5" grinder, went through about 5 cut off wheels. I was hoping a larger angle grinder would be the trick? I have a cutting torch, but I really want more of a machine cut look..
Bill Gilbert
bgilbert
Postby bgilbert » Mon May 25, 2015 11:44 am
I have a box of 25 6" cutoff wheels, maybe I go with a 6" 'small' angle grinder :lol: ? I've never used anything bigger than a 4.5" grinder. Are you saying the bigger grinders are a beast to hold onto, and not fun with a cutoff wheel? lol
bgilbert
Postby ellis93 » Mon May 25, 2015 12:31 pm
If you buy newer stuff then you can probably handle them. The ones with the "soft start up" have some sort of computer chip governor thing in them (I've been told this,there for its hear say).
They are just heavy as hell. I would thing a man would work himself to death over one :lol:
Look into a Metabo....they take a big blade and are only for what your trying to do.
Oh and harbor freight sells those plates.....you might have to order them,but they do sell them.
Postby oldestof11 » Mon May 25, 2015 12:41 pm
I have put my Makita 4" and 4.5" grinders through hell and back. Worth the $55-$100 to get one. My 4.5" lasted 7 years of cutoff duty from siding to 1" thick steel. Finally died when the armature burnt up. 1 set of brushes. I expect this 4" I bought to last half as long. It is doing well for the last year I have had it.
Postby ellis93 » Mon May 25, 2015 12:46 pm
While not cheap.....they are a good tool
Postby PToombs » Mon May 25, 2015 4:24 pm
I think I'd use the torch, go slow, and clean up with the grinder. But that's just my opinion.
Those Metabo grinders are tough SOBs. We have a 4.5 inch one at work that was there when I got there 16 years ago and is still going strong. It gets abused because everybody grabs it to grind stuff they should be grinding with the 7" unit. A lot of money but it's a great case of "you get what you pay for!"
Postby bgilbert » Mon May 25, 2015 4:38 pm
ellis93 wrote:Oh and harbor freight sells those plates.....you might have to order them,but they do sell them.
Not for one this big! The bed is 10" ID. Then 3" on either side. My HF 20 ton unit has 8"x8"x1" cast plates. This 3 foot square 1" plate came with the press, so I'm going to try and put it to use. I'm sure by the time I get down to the last couple pieces, I'll use the torch.
We also have a Metabo at work, we used to sell them too. Well, I should say we used to stock them. Nobody bought them lol. I've searched online and most of the bigger grinders say they have the 'soft start'. Think I'm going to get a 6" Milwaukee angle grinder. Thanks.
bgilbert
Postby RumbleFish » Mon May 25, 2015 5:13 pm
Dad borrowed a metabo from work before he retired. Im pretty sure he loves it more than he loves me. Its a really nice tool.
Postby ellis93 » Mon May 25, 2015 5:52 pm
Oh :lol:
Postby BILTIT » Tue May 26, 2015 5:55 am
Torch, plasma cutter or water jet.
Derek B.
BILTIT
Postby bgilbert » Sun May 31, 2015 1:21 pm
Well apparently free shipping from Northern Tool means your item won't even ship for at least a week, then take another week to arrive :roll: . So while waiting, I took Pete's advise, got the cutting torch out and started cutting a small section. Turns out if you take your time, you can make some decent cuts. I was surprised. Then a few minutes with a 40 grit flap wheel cleaned up the cut. I'll be doing the rest of the plate with the torch now lol. Might just send Northern their 6" angle grinder back? :lol:
bgilbert
Postby PToombs » Sun May 31, 2015 5:17 pm
See? Us old guys DO know how to do more than drink beer and BS. :mrgreen:
Return to Shop
