who makes the best sawzall blade
A place to BS about tools and all that junk
Postby james-93-12valve » Tue Sep 29, 2009 7:11 pm
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby Philip » Tue Sep 29, 2009 7:14 pm
Of all the ones I have tried. Milwakee seems to last the best.
Postby RumbleFish » Tue Sep 29, 2009 7:22 pm
ill 2nd that. or whatever you can steal from your workplace.
id rather change free blades frequently than pay for good ones.
Postby TTipswprd » Tue Sep 29, 2009 7:25 pm
safety award! :wrench:
TTipswprd
Postby ahale2772 » Tue Sep 29, 2009 7:49 pm
the new "torch" ones are no good at all even if oiled they wear fast
Postby james-93-12valve » Tue Sep 29, 2009 8:57 pm
Philip wrote:Of all the ones I have tried. Milwakee seems to last the best.
thats wat ive been usein but some one told me lennox were the best
james-93-12valve
Postby PToombs » Wed Sep 30, 2009 6:10 pm
So buy a pack of each and report back to us. We like to learn new things.
Except for what Jeff is gonna do when he finds out Jeremy has sheep now. :?
Postby Ggg » Wed Nov 18, 2009 1:50 pm
I have not been impressed with Milwaukee blades but they are better than DeWalt. I like Lenox blades a lot and go out of my way to buy that brand.
Ggg
Re: who makes the best sawzall blade
Postby huntinguy » Sun Apr 11, 2010 10:34 am
Lennox are the best.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby moose5.9 » Thu Dec 19, 2013 9:48 am
I really like the diablo seires that home depot sells
DD: 99 nissan frontier
sold: 97 F250, 7.3l d60 swap, billet pushrods,elec.fuel, gauges, dual 5inch side pipe,
moose5.9
Postby grinnergetter » Fri Dec 27, 2013 7:15 pm
I have used Dewalt, Milwaukee, Ace brand, B&D, Lenox .....I never ever buy anything other than Lenox. How many of the others can you bend in a L shape...multiple times...bend it back and keep on cutting.
I would rate them in this order:
Lenox
Milwaukee
Dewalt/Ace
B&D
grinnergetter
Postby joshotto94 » Tue Jan 28, 2014 1:30 pm
i like Milwaukee and Dewalt thats what i tend to grab just depends what hardware store im at
joshotto94
Postby 1992gen1_fan » Wed Mar 19, 2014 3:25 pm
I've had good luck DeWalt blades for metal cutting, also Lenox work well. I've never had any good luck with store brand cheap junk. I've found that the more expensive ones are generally cheaper to use when it comes to reciprocator/sawzall and jigsaw blades.
1992gen1_fan
Postby 93oneton » Sun Jul 24, 2016 12:30 pm
We use lenox at work. They seem to be the best we have found.
Shit happens
93oneton
Postby 1320Fastback » Thu Jul 28, 2016 8:44 pm
We use literally thousands of sawzall blades every year at work.
My company only buys Lenox.
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Return to Shop
