Air Compressor
A place to BS about tools and all that junk
Air Compressor
Postby meby » Tue Mar 23, 2010 2:24 pm
I have an air compressor that I would like to convert from 220 to 110. How do I do this?
Thanks,
Matt
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Air Compressor
Postby swank » Tue Mar 23, 2010 2:40 pm
It might be as simple as taking a little plate off the back of the motor and looking at a little diagram and switching a couple wires around. Check and see if there is a little sheetmetal plate near/at where the wires go into the motor and report back.
truck
swank
Re: Air Compressor
Postby 1STGENFARMBOY » Wed Mar 24, 2010 6:22 am
I also may be able to help since that is what i do all day every day, well sometimes i get on
here and post stuff but i really need to be workin on motors since there are 9 more than there
were yesterday :shock: .....I HATE ELECTRIC MOTORS , :lol: but i guess i'll have to live with
them for a few more years. back to the problem if its made to run on two voltages the nametag will
say ...110/220 and also have two amp ratings. let us know if you need help. ;)
Re: Air Compressor
Postby diesel freak01 » Wed Mar 24, 2010 7:43 am
what about converting a 3 phase to a single phase motor? *i know i know change the motor out right?*
1993 d350 ctd drw 2wd auto
diesel freak01
Re: Air Compressor
Postby 1STGENFARMBOY » Wed Mar 24, 2010 9:32 am
Cant do it, well you can but it would cost major $ and time.
Re: Air Compressor
Postby diesel freak01 » Wed Mar 24, 2010 10:39 am
i can buy a 5 hp electric motor for a compressor from northern tool for 189 bucks?
diesel freak01
Re: Air Compressor
Postby 1STGENFARMBOY » Wed Mar 24, 2010 10:51 am
Well let me say this gently, that motor might work for a while but like everything you get what you pay for
and a halfway good motor should cost somewhere around $275-325 thats if its got a 56 frame, if its a 184T
frame your talkin $450-600 :shock: . look for an AO smith or marathon or magnetek/century or baldor those are
pretty good quality motors. its unbelievable but i can buy a new puma compressor 6hp? twin stage pump 30gal tank for what i can get just a motor
for sometimes. hope this helps you fellow jetta tdi owner. :lol: tell me the amp rating and hp and rpm and frame and i'll price
a motor for you so you don't get skinned. ;)
Re: Air Compressor
Postby meby » Wed Mar 24, 2010 2:19 pm
I will find out what the tags say and get back with you.
thanks,
-Case 530 CK
www.ebyfarmsllc.com
meby
Return to Shop
