by MMiller » Tue Jun 04, 2013 10:56 am
I talked with Ryan at Hamilton. He thought a 188/210 cam would be a good fit in my truck. I would have to get some of the 60# valve springs, and I figure on getting new lifters. We talked about 24 valve or common rail lifters. The 24 valve lifters are about 1.3" diameter at the area that rides on the cam, and common rail ones are 1.5". He said I could use either one, just be sure to tell him when I ordered, and he would make sure the cam was clearanced so those lobes didn't interfere with the lift pump. I suspect since the lift pump isn't there on a 24 valve and common rail they can make the lobes and lifters wider in that area, but in an application that uses a lift pump it may cause issues.
When its all said and done, buying a cam from Hamilton, new valve springs, and new tappets, with some shipping, I'm right around $950. Ouch. If I were to put in a stock cam, 60# springs(that I should have anyway) and lifters it is about $750. I'm going to call a guy about having a stock cam re-ground later today.
Ryan also advised that newer oil does not have enough Zinc in it(something the gas powered racers are having troubles with too) and I should start adding it to my oil to help areas like the cam/lifters for wear. Bgilbert brought a good question up when he called me today. Does the larger lift/duration camshaft move the hp up in the rpm range like a gas engine application? I need to make sure of this, because I don't want anymore top end power.
Michael
