24 valve cam
24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 6:45 pm
So my buddy sold his 24 valve and has a brand new helix 2 cam. That he will sell me for 250$.will this can work in my engine.I hope it does cus a Hamilton is expensive
warhammer92
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 6:53 pm
Yes, you can...........however they don't have a lift pump lobe.
Re: 24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 7:00 pm
So I have to buy an electric lift pump so I'd still come out to the same price
warhammer92
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 7:07 pm
Pretty much
Plus, the Hamilton 188/220 seems to be quite the ticket right now.
Re: 24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 7:22 pm
Yeah I'm just worried with clearance and kinda want to be on the safe side with the 188/208.
Found out how muchh they took off my head and block.it was .065
warhammer92
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 7:24 pm
Ah......
Re: 24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 8:42 pm
Anything over stock is better.plus Im not revving it higher than stock rpms so I wouldn't really benefit the 188/220
warhammer92
Re: 24 valve cam
Postby Remps » Thu Jul 25, 2013 8:58 pm
The 188/220 actually makes the most bottom end power, perfect for a VE.
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 9:09 pm
The common thinking is the larger the cam the better for high end........there is a lot of truth to that, but the 188/220 seems to make the most bottom end.
Remps is dead on what the testing has shown so far.
Re: 24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 9:57 pm
You guys are putting me in quite a predicament now.I want to make low end power but I don't want to spend 600$ and be screwed
warhammer92
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 10:07 pm
Call Zach Hamilton.............
Re: 24 valve cam
Postby warhammer92 » Thu Jul 25, 2013 10:30 pm
I did.he said run the 220 if I had enough clearance but said the 208 would also be a good choice
warhammer92
Re: 24 valve cam
Postby RCCUMMINS89 » Thu Jul 25, 2013 10:35 pm
He didn't give you any words of encouragement or lack of encouragement whether it would clear?
Well, poo.
Re: 24 valve cam
Postby turboram » Sun Jul 28, 2013 2:33 pm
I put a 188/220 in several motors and they clear fine
turboram
