turbo housing
turbo housing
Postby tradtke » Fri Aug 09, 2013 10:17 am
OK so I just got played today and I'm considering buying a 16cm exhaust housing for my stock h1c. Is it worth it? How much more boost does it give you? And where's the cheapest place to get one?
tradtke
Re: turbo housing
Postby ellis93 » Fri Aug 09, 2013 10:19 am
As far as I know,it won't make more boost.....it'll help spool the turbo quicker letting it build boost faster.
It's a very worthwhile upgrade
Check with the hungry diesel on one.
Re: turbo housing
Postby DodgeFreak » Fri Aug 09, 2013 10:21 am
I went from a 21cm to a 16 not sure if I seen much more boost, turbo lag was a lot less. if you have the 18 cm you won't notice much if any difference. I paid 50 bucks for mine I believe used.
Re: turbo housing
Postby tradtke » Fri Aug 09, 2013 10:43 am
That sounds like a pretty good deal to me. I got the 21cm right now. I can't really seem to fund any under about 150 or 160 dollars.
tradtke
Re: turbo housing
Postby Tacoclaw » Fri Aug 09, 2013 12:09 pm
If it's a stick truck I'd look for a 'gated 12cm housing off an HX35, drill out the divider, and enjoy some cheap, fast boost. Wouldn't give more than $100 for one.
If its an auto, find an 18cm and run it, they're dirt cheap and everywhere. No use paying ~$200 more for 2cm difference in area, like said above, you'll never notice it.
Re: turbo housing
Postby DodgeFreak » Fri Aug 09, 2013 3:03 pm
theres a parts HX on cummins forum for 150.
Edit: heres the posting http://www.cumminsforum.com/forum/gener ... turbo.html
It does have the back plate with the elbow so you'd have to buy another one with just the flange. comes with new wheel and you can run your shaft\turbine. backing plate is the only thing you'd have to deal with.
Re: turbo housing
Postby ellis93 » Fri Aug 09, 2013 4:06 pm
That whole thing would be a significant improvement on your truck! 2mm bigger inducer,more boost/HP capability,decent price......you can't go wrong ;)
Re: turbo housing
Postby tradtke » Mon Aug 12, 2013 12:39 pm
So if I were to get that what all would I need to do to put it on my truck
tradtke
Re: turbo housing
Postby ellis93 » Mon Aug 12, 2013 1:34 pm
Should bolt right on and you'd use your own connections on your existing turbo
Re: turbo housing
Postby RCCUMMINS89 » Mon Aug 12, 2013 1:55 pm
The exhaust housings on the h1c, hx35, and wh1c are all interchangeable. It's as simple as swapping them, nothing else to it.
Best bang for the buck is to find a blown up hx35 with a good exhaust housing and flop it on your h1c.
Re: turbo housing
Postby cmann250 » Mon Aug 12, 2013 3:49 pm
The HX is a great and cheap upgrade. I'd knock the guy down quite a bit on price. I know I only paid $80 for mine :lol:
RCCUMMINS89 wrote:The exhaust housings on the h1c, hx35, and wh1c are all interchangeable. It's as simple as swapping them, nothing else to it.
I've heard contradictory information, but can't say I know myself. When in doubt, break it apart, measure the parts to be swapped, and reseal it up.
Re: turbo housing
Postby Tacoclaw » Mon Aug 12, 2013 5:21 pm
It's true, I've got an HX35 housing on my old H1c.
Re: turbo housing
Postby DodgeFreak » Mon Aug 12, 2013 6:44 pm
tradtke wrote:So if I were to get that what all would I need to do to put it on my truck
you need to swap the rear exhaust flange for an older hx. That one has the elbow casted on to it. Once you find the right rear plate or make one it will bolt right up.
The HX housings are the same as the H1c
the Hy's are different
