rebuilding a 351cw
rebuilding a 351cw
Postby DodgeFreak » Thu Dec 19, 2013 9:12 pm
Hey, guys I'm rebuilding the 351 using a hx shaft and I think I've ran into a couple problems.
First one is where the turbine seal rides is a lip and the hx center doesn't have that lip. 2nd is the compressor seal looks like its completely gone and it has ate the edge of the retainer just alittle. will the hx retainer (not sure if that's the correct term) fit?? It looks almost identical to the cw.
Also There is 5 little snap rings and I only remember taking 4 out. I took out and installed the two inside snap rings for the bushings and the two outside ones. where does the 5th go??
I have a pic of the turbine side but not the compressor side. Thoughts would be appreciated before I go much further.
Re: rebuilding a 351cw
Postby DodgeFreak » Fri Dec 20, 2013 7:59 pm
Anyone?? Thats the only thing keeping me from finishing it beside the comp wheel
Postby BILTIT » Sun Dec 22, 2013 11:27 pm
I am pretty sure only 4 small snap rings are needed.
Derek B.
BILTIT
Postby DodgeFreak » Mon Dec 23, 2013 5:38 am
Thanks! Is there supposed to be that lip on the turbine side for the sealing ring??
Postby BILTIT » Mon Dec 23, 2013 4:09 pm
I am not sure.
Derek B.
BILTIT
