Sutter1stgen wrote:DMan1198 wrote:it'll run fine up to 10 degrees off center
I have often wondered if there really was a set number. As I've track packed a few overpasses, and slopes with a dozer.
I was in a serious reclined position for hours on end, 1:1,1.5:1, and even some 2:1 slopes. That turbo didn't auto level, and it lasted.
Not knocking you, I'm curious as well to know a definite answer as to what is too much permanent incline for turbo to last. For all I know as long as your feed is still your feed, and your drain is still your drain, you may be good!! Lol
