Good source for 155* nozzles?
Postby Joecochrane » Fri Jan 17, 2014 10:30 pm
I'm in the market for bigger nozzles but all I see is 145's running a industrial motor out of a bus looked up the cpl and it states I have non egr pistons. But any where such as dap or ebay or any place I look only has nozzles for the 145 spray pattern. I don't wanna buy full injectors because I have a p pump and most of the parts for the swap on a shelf. I just wanna make a ill power until I'm ready to rip the truck apart.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: Good source for 155* nozzles?
Postby RCCUMMINS89 » Sat Jan 18, 2014 2:48 am
Pm me with what you are looking for.
