4x4 frame
4x4 frame
Postby 92cummins89 » Fri Feb 09, 2018 9:24 pm
I’m looking at buying a donor truck that is 2wd an I have a 4wd do they have the same frame ?
1992 4x4, 4ā€ diamond eye exhaust, nv4500, he351cw
92cummins89
Re: 4x4 frame
Postby thrashingcows » Sat Feb 10, 2018 2:58 pm
The frames are the same as long as it's a cummins truck, but you will have to cut/grind/drill/pound out all the cold rivets on both frames, then measure and drill all the 4wd relevant holes in the frame, then swap all the 4wd components over to the 2wd frame....easy, done in an afternoon. :?
thrashingcows
Re: 4x4 frame
Postby 92cummins89 » Sun Feb 11, 2018 9:25 pm
Well was gonna buy it but was too late o well
On mine I need two strip mine down to the frame bc the previous owner Bent the sthi outta that piece of flat brace An I need to go back in an fix it right
92cummins89
Re: 4x4 frame
Postby erroljon » Thu Apr 26, 2018 11:40 pm
Haven't you look for another option?
erroljon
