Fuel Filter Question
Postby Iurynnt » Tue Apr 09, 2019 11:55 pm
The old Dodge is turning 5 years old next month and the O.D. just rolled over 12.5k miles. I'm wondering about the life span of the fuel filter. I know you are to change them out every 15k, but I'm still using the original filter. Should I change out the 5 yr. old filter or is it not a problem to wait for another 2500 miles.
Also, any good air filters out there for the 6.7 Cummins https://bestarny.com/air-filters-for-6-7-cummins/ or should I stick with the OE filter. On my last Ford Diesel, I was told thatr the Ford filters were the way to go.
Iurynnt
smoke screw?
Re: Fuel Filter Question
Postby spencerdiesel » Thu Apr 11, 2019 6:24 pm
I’d say if it’s between: wondering if the extra year/ 2500 miles is ok to run, or changing it now for peace of mind, peace of mind is worth a lot to me :D
You’ve gone 5 years without having to worry about it, go ahead and change it and be worry free for another long while.
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
