60# valve springs
60# valve springs
Postby cougar » Tue Apr 09, 2019 8:55 am
Finally got them in. More valve train noise. Runs better, but I attribute that tho the valve adjustment.
01 2500 "the work truck".
cougar
Re: 60# valve springs
Postby Begle1 » Tue Apr 09, 2019 11:16 am
They're not supposed to do any good until you're above 3000 RPM, right?
Postby PToombs » Tue Apr 09, 2019 4:37 pm
Being a stronger spring they make the valves close faster at all speeds. At the higher rpms they should have enough strength to keep the boost from blowing the valves open and/ or floating.
Postby cougar » Wed Apr 10, 2019 8:50 am
Considering my VE has been tuned to 4,000 RPM, the stiffer springs were kinda necessary.
cougar
Postby DMan1198 » Fri May 10, 2019 2:37 pm
I found when I did valvesprings on my 6.7 I noticed a difference in performance, and I’d done a valve set the previous month when I did studs, so it’s not the setting the valves that makes a difference.
