Just a little more . . . . .
Postby Richie O » Wed Feb 05, 2020 7:33 am
I assume thats where they break when you see the cylinders come off the block in the dyno, and pulling videos?? Man thats not good. Talk about a kick in the pants.
Postby BC847 » Sun Feb 16, 2020 4:17 pm
Richie O wrote:I assume thats where they break when you see the cylinders come off the block in the dyno, and pulling videos?? Man thats not good.
I tried my best . . .
Postby BC847 » Sun Feb 16, 2020 4:28 pm
Finally got a lift, dry weather, . . . . initiative . . . . :roll:
Screw taking things completely apart to get the block out . . .
The head presents with uniform carbon/soot patterns across the cylinders it seems . . .
Typical . . . (swirl inducing valve reliefs) . . .
Swirl pattern? (typical of all six) . . .
The pistons all look like this . . .
Fuel impingement [Stock/OEM piston and injector angle (145*)] . . .
Yeah, . . . . From that in the oil-pump recess all the way back to the turbo lube-oil return port . . .
Postby dazedandconfused » Mon Feb 17, 2020 7:32 am
I think you got all of the life out of that one.
Postby Philip » Tue Feb 18, 2020 8:06 am
dazedandconfused wrote:I think you got all of the life out of that one.
Yes he did
Postby PToombs » Sat Feb 22, 2020 8:50 am
Wow! That could have been really bad if it popped at the track! The good news is that it looks like you had the fuel and timing set about perfect.
Postby BC847 » Sat Feb 22, 2020 2:47 pm
PToombs wrote:Wow! That could have been really bad if it popped at the track! The good news is that it looks like you had the fuel and timing set about perfect.
- Indeed, it could have been a big mess had I been coming off the line at WOT.
- I'll be using a different piston to better optimize stuff with the new build.
It's phackin amazing the people who post engines/parts for sale yet come off as reluctant (at best) to get off their ass and actually make the sale. :mad:
Postby BC847 » Tue Feb 25, 2020 5:42 pm
- Got a complete (less turbo, injectors and cam) '93 VE fueled engine on the way.
- Vacuumed the shop floor. Everywhere! Two large bags of pecans and squirrels. (Do the math).
- Cleared the bench of transmission crap!
- Put the valve-covers, the lube-oil cooler cover-plate, the lube-oil heat-exchanger, the remote lube-oil filter-head, it's bracket and hoses, the AC compressor mounting bracket in a bath of metal-safe detergent.
Off tomorrow. We'll see if I make anything of it.
Postby BC847 » Wed Feb 26, 2020 8:03 pm
- Pressure-washed the valve-covers, the lube-oil cooler cover-plate, the lube-oil heat-exchanger, the remote lube-oil filter-head, it's bracket and hoses, the AC compressor mounting bracket.
- Pressure-washed the exposed, general area around the remaining block as it sits in the truck.
- Pulled the cam and lifters.
- Inspected the cam, lifters and pushrods.
- Wept a little.
I got 188/220 steel cam and 24v lifters from Zach in Feb of 2012. I'd been running his 110 (?) valve-springs with his 1st stage HD (whatever) pushrods.
Anyhoo, pulling the cam out this afternoon and standing back and looking at stuff reveals things like:
- The lobes of the cam have a surface of anywhere from smooth to heavily cratered (?)
- The lifters smooth to heavy cratering (?)
1 - Exhaust . . . .
3 - Intake . . . .
5 - Exhaust . . .
All of the lobes present with shadows on the ramps . . .
I'm gonna go out on a limb and say I've gotten my monies worth from the rods, huh? Some have grown nipples.
I've always run a good dose of the ZDDP supplement stuff with Rotela. Ya reckon there's any salvaging of that cam?
Crap! :cry:
Postby Richie O » Wed Feb 26, 2020 9:43 pm
I worry about most of our equipment. I suspect all of my diesel equipped stuff has flat tappet. This low zinc deal sucks.
Postby PToombs » Thu Feb 27, 2020 3:13 pm
BC, you think it's the lack of ZDDP that caused the cratering? I dumped a couple bottles in when I changed the oil once, but the darn stuff was about $15 a bottle so I gave that up.
Postby BC847 » Thu Feb 27, 2020 4:37 pm
PToombs wrote:BC, you think it's the lack of ZDDP that caused the cratering? I dumped a couple bottles in when I changed the oil once, but the darn stuff was about $15 a bottle so I gave that up.
IIRC, I ran two bottles of the stuff with the installation of that cam.
- I always add a bottle with each oil change.
Come to find out, there's a difference in the ball size (that which sticks in the lifter) between the 12v lifter and the 24v lifter. No wonder the weird wear. DOH! :grrr:
I'd been running the earlier lifter and pushrods with the former 181/210 cam. THEN, put in the 188/220 cam with the 24v lifters.
Huh. :roll:
