Fuel Filter Question
Postby Iurynnt » Tue Apr 09, 2019 11:55 pm
The old Dodge is turning 5 years old next month and the O.D. just rolled over 12.5k miles. I'm wondering about the life span of the fuel filter. I know you are to change them out every 15k, but I'm still using the original filter. Should I change out the 5 yr. old filter or is it not a problem to wait for another 2500 miles.
Also, any good air filters out there for the 6.7 Cummins https://bestarny.com/air-filters-for-6-7-cummins/ or should I stick with the OE filter. On my last Ford Diesel, I was told thatr the Ford filters were the way to go.
Iurynnt
smoke screw?
Re: Fuel Filter Question
Postby spencerdiesel » Thu Apr 11, 2019 6:24 pm
I’d say if it’s between: wondering if the extra year/ 2500 miles is ok to run, or changing it now for peace of mind, peace of mind is worth a lot to me :D
You’ve gone 5 years without having to worry about it, go ahead and change it and be worry free for another long while.
Postby bensol64 » Mon Oct 14, 2019 8:15 pm
The Fleetguard FS1221 is another good filter for the first gen.
bensol64
Postby Begle1 » Mon Dec 16, 2019 11:45 am
If you have a pressure gauge post-filter and see pressure never dropping off, would anybody still change the filter?
Postby PToombs » Mon Dec 16, 2019 4:35 pm
Depends on how much you drive it. If you drive it quite a bit I'd change it every 2-3 years anyways. I run mine maybe 4-5k a year and change filters about that often.
Postby Ace » Tue Jan 11, 2022 6:56 am
Filters filter better the longer they stay in service, right up until the point where they no longer flow enough.
Postby Ace » Tue Jan 11, 2022 7:04 am
Begle1 wrote:If you have a pressure gauge post-filter and see pressure never dropping off, would anybody still change the filter?
Only if it's been years and I really have nothing better to do. Jiffy Lubes all across the country have dumpsters full of perfectly good filters behind them. But you need to worry more about the engine oil. And don't forget to filter the coolant, as well.
