How much water to run? McMaster Carr nozzles?
Water?
Postby Ace » Mon Apr 07, 2008 10:27 am
I never knew you could run water in a hydraulic pump. Well, at least not for very long, before the seals or something else lets go.
Postby Begle1 » Mon Apr 07, 2008 10:36 am
That's why you mix cutting fluid in the water at a 1:15 ratio.
Or so somebody said...
Postby CumminsPride » Mon Apr 07, 2008 11:25 am
Why couldn't you use the old heap you have with a 12V belt clutch from a mower? Or even an AC Compressor Clutch!
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby flashgordon » Mon Apr 07, 2008 11:37 am
Begle1 wrote:Here's a unit that screams like it wants to be used.
http://cgi.ebay.com/12V-Hydraulic-Clutc ... dZViewItem
Still way overkill though... But when it's cheaper than a Harbor Freight powerwasher who cares?
I like that one!!!!!!Having a AC type clutch on it and all.............To bad it hasn't go a surp belt pulley.
Flash
flashgordon
Postby Begle1 » Mon Apr 07, 2008 12:00 pm
Mower clutch, eh? That's a thought.
Think that an A/C clutch would be strong enough?
I see the thing having a giant pulley on it so that it doesn't spool itself to death... Hydraulic pumps all seem to be rated at 1000 RPM...
Postby Begle1 » Mon Apr 07, 2008 12:27 pm
How about this mower clutch off eBay? It's local... Seems like the biggest horsepower tractors they had it on were in the 10-20 HP range though...
How much HP do you think I'm gonna pull?
