Ok, so my hx35-12 has the waste gate wired shut right now, as I took it off of a piece of equipment and the bracket that holds the wastegate on for the app put it right in my oil drain location for my app. This leads me to my next conundrum. Should I just build a bracket for the hx35-12 drill out the internal wastegate, or should I just build a log manifold, and incorporate an external gate? It would be a little more work, and a little more money to go this way, but would it be worth the effort? I think I have a 44mm gate sitting around here from another project, and I'm pretty sure I can get a 60mm gate fairly easily.
Too the second part of my wonderings. I have a Holset HT-60 that needs a rebuild, I also have a Garrett GT 4294 journal bearing, with a 1.34 exhaust housing, (T6 flange) in good shape. I want to run a tow able 500rwhp. I have a 24ft wells cargo race trailer, that I use to pull a race car a couple times a year, but mostly it is just a play truck.
