KTA wrote:What actually happens is you move the control collar to the point where the governor is no longer capable of uncovering enough of the spill port to produce the correct idle fuel quantity.
Begle1 wrote:KTA wrote:What actually happens is you move the control collar to the point where the governor is no longer capable of uncovering enough of the spill port to produce the correct idle fuel quantity.
Is there a diagram or picture of that anywhere?
bgilbert wrote:It's all in the readily online available pdf formatted VE Manual.
