GO OVRIT wrote:So what filters and heads are you guys running when bypassing the factory filter. I've used the search and havn't come up with much. I've got an a1000, boost referenced regulator and enough 1/2 and 5/8 line to plumb it. Also what size line should I run from the regulator to the pump? 3/8?
