leaf spring bushings
Postby DTanklage » Thu May 29, 2008 11:58 am
how many would be interested in high quality custom urethane bushings for the first gen?
wouldnt have to be for the leaf springs only but i thought about those first cuz i know how stupid skyjacker is
my truck still has the bolt floppin around in the bushing
set up is expensive but if i can find enough of us to make it work out it sure would be sweet
lemme know
DTanklage
Why Not Just Buy Them
Postby Ace » Thu May 29, 2008 2:19 pm
These are off-the-shelf parts available from dozens of distributors, choose your color. Why would you do this?
http://www.suspensionconnection.com/cgi ... 005DF.html
Or I dunno, try bigger bolts maybe?
Postby Philip » Thu May 29, 2008 3:04 pm
If you call that place you listed I bet you would find out those spring eye bushings they list are for 1/2 bolts. 91.5/93 model CTD trucks have 5/8's front spring eye bolts in them.
If you order a set of skyjacker soft ride springs they send the 1/2 bolt bushings no matter what you tell them. After they ship you the wrong front spring eye bushings do not waste your time calling eather. Been there, done that.
Postby Ace » Thu May 29, 2008 4:11 pm
Mine's got 1/2" bolts.
Postby DTanklage » Thu May 29, 2008 5:15 pm
so in other words no one cares if their truck is right or not?
DTanklage
Postby PToombs » Thu May 29, 2008 5:17 pm
I'm glad mine is 2wd, way less stress! :clown:
Postby GO OVRIT » Thu May 29, 2008 5:35 pm
I got my alcans done with rubber bushings and 5/8s bolts. Are you going to have some made? With the steel sleeve? I might be interested in some to use to make links with for my Jeep.
GO OVRIT
Postby DTanklage » Thu May 29, 2008 10:14 pm
i can get em any size or shape
with or without a sleeve
but there is set up time involved
i am not going to do it for my first gen unless at least a few others want to do it too
still cant believe skyjacker ships em like that well aware of what is going on
arent the 2wd guys gonna eventually want new rear springs?
DTanklage
Postby bradshaw106 » Fri May 30, 2008 1:34 pm
i would be interested. i really want to replace my bushings. would you be doing shackle eye as well?
92 4wd 180k auto, 366 spring, turned fuel pin, loaded
first diesel!
bradshaw106
Postby DTanklage » Fri May 30, 2008 6:36 pm
the stock 1 ton springs have a larger 'eye' than the skyjacker replacements
if i were you i would just use moog stuff
guess that goes for the 3/4 ton guys too?
DTanklage
