169417 turbo
169417 turbo
Postby Cschafer » Wed May 28, 2008 1:59 pm
I pulled off the intake today and found about .025'' endplay on the turbo. HTT said pull it off and send it to them for a minumum of $300. I was thinking I wanted the 71mm wheel and 14 housing anyway. Is the 169417 exactly what all the companies are scalping you for with there name on it or is there some differences. Local truck store can have a new one hear on friday for $700 as long as it's the same I'll get it coming.
91 w250 wrecker
Cschafer
Postby KTA » Wed May 28, 2008 3:07 pm
It has a diffrent exhaust housing. It is bigger and non wastegated.
Postby Fnschlaud4620 » Wed May 28, 2008 5:06 pm
how do you know that? Do you have a book that tells all of the turbo specs? Do you know what common part number to order from a regular turbo place, rather than getting raped by Htt or I.I.?
Thanks
Fnschlaud4620
Postby Cschafer » Wed May 28, 2008 8:27 pm
how much bigger? Wastegate is not important because I'm gonna run a external gate anyway but spoolup is. Will the housing on my s300 fit it. Can you get a part number for any other s300 combos, like one with a wastegate or smaller non gated or something with a 74mm ex wheel like the silver bullet? Thanks for the help.
Cade
91 w250 wrecker
Cschafer
Postby DTanklage » Fri May 30, 2008 11:14 am
the housing prolly isnt set up for a 4" v-band clamp either so you might want to keep that in mind. post your findings please, cuz thats exactly what i am looking for (62-74/16)
whos waste gate are you running?
and what power level do you plan on using that turbo at?
any towing?
thanks, don
DTanklage
Postby SChandler » Sun Jun 01, 2008 10:16 pm
Fnschlaud4620,
Most of the specs were posted in the "P-pump chasin" thread. This website (http://www.centralturbos.com/pop-werks7a.htm) has almost all of the dimensions listed for the 169417. It lists the turbine housing as a 1.15 A/R ratio. Anybody know what that is in cm^2?
SChandler
Postby GLHS » Sun Jun 01, 2008 10:49 pm
I posted my answer on TDR. Will do so again here.
A .70 housing is considered a 12, a .80 is around a 14 so yours might be around a 21?
GLHS
Postby SChandler » Mon Jun 02, 2008 8:28 am
Thanks for the info GLHS. I'm not entirely sure that you can say that a .70 is always a 12cm^2 though. A/R is a ratio so it will be affected by the two inputs. For instance 12/17.1 = .70 A/R but so does 16/22.9 (if my understanding of A/R is correct, I'm using this site for guidance: http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html). A/R is affected by how tall or short a turbo is, right?
SChandler
Postby DTanklage » Mon Jun 02, 2008 10:05 am
it is how big the housing is
dont know why they have to have two diff methods of measure?
area divided by radius has been around how long
dont know what you mean by tall or short
DTanklage
Postby Cschafer » Mon Jun 02, 2008 11:25 am
I don't own this turbo I was thinking about buying one because my htb2 has end play and it's not big enough to go for 500 as a single. I don't really want to waste 700 dollers on somthing I can't spool either. If the a/r was closer to a 18 or 19 I might try it, it should make some good power. I think I'm just gonna send my htb2 in and have it rebuilt.
91 w250 wrecker
Cschafer
Postby CumminsPride » Mon Jun 02, 2008 2:15 pm
So what does this translate out to be? GTP38, GARRETT / NAVISTAR 1825878C91 /compressor a.r.= 1.10 exhaust a.r.= 0 .84
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby SChandler » Mon Jun 02, 2008 2:24 pm
DTanklage wrote:it is how big the housing is
I was trying to say that a/r is influenced by housing size both in cross section (cm^2) and by radius of the housing (cm). In theory, you could have two turbos with the same a/r, but different cross sections due to the difference in the radius of the turbos. I was trying to say that a shorter or longer radius would change the ratio. In this case, I don't think that a ratio is the easiest method of distinguishing turbo sizes. Although, I suppose it allows for relative performance comparisons between turbo models (i.e. a 62/71 turbo with a .70 vs. a 1.15 A/R) but using it between models is less than ideal, in my opinion. Could be that my limited understanding of turbos prevents me from fully appreciating a/r, but I think it would be better if they would post cross section areas as well as a/r.
SChandler
Postby SChandler » Wed Jun 04, 2008 8:55 am
From the link to GDS' website that roxxx posted in his thread (http://www.gdsdieselparts.com/s-300_(b1_2)_turbos.htm), for the S300 turbo a .70 A/R = 12.06 cm^2 and a .80 A/R = 14.77 cm^2.
SChandler
