Nutty injector line idea
Postby cummins king » Tue Jun 10, 2008 8:41 pm
So leave it up to me to come out with this idea
Why cant we take 1/8th (.125 very big yes) grease lines that are rated to 6000psi put the right ends on it and bolt it up from the injection pump to the injectors, i know the ends would be the tricky part, but not impossilbe, is there any reason why it wouldnt work?
Joel
93 4X4 auto
cummins king
Postby VEfreak » Tue Jun 10, 2008 9:11 pm
I heard ve's don't like really big injection lines unless they are moving gratuitous amounts of fuel. And those are really, really, ridiculously huge.
But that's just hear-say coming from me.
VEfreak
Postby PToombs » Wed Jun 11, 2008 5:03 pm
Might be kinda tough. Remember, the lines all have to be the same finished length. ;)
PS, can you send me some of what you're drinking? I need some inspiration! :lol:
Postby GLHS » Wed Jun 11, 2008 7:11 pm
I thought ve pumps could make upward of 12,000 psi?
GLHS
Postby cummins king » Wed Jun 11, 2008 7:48 pm
ya i dont even know what im drinking, i need more of it, lol, maby its the Tim Hortons Green tea, hehe
I dont see there being a problem being all the same lenghts
it would be so unstreetable, though
and ve's make 3000 to 4000 psi
Ck
93 4X4 auto
cummins king
Postby KTA » Thu Jun 12, 2008 6:36 am
My VE makes more than that or it wouldn't run. It takes 3600psi just to get the injector to open, any less and it won't fuel and no fuel means no run. :roll: Depending on injector flow and fuel delivery rates the peak pressure in the VE can be in the 12000 psi range pretty easy.
Postby cummins king » Thu Jun 12, 2008 7:13 am
I guess i was wrong, learn somthing new every day
Thanks Brain
93 4X4 auto
cummins king
