regret p pumpin
regret p pumpin
Postby railhor5.9 » Mon Jan 05, 2009 6:29 pm
well i bought a 94 dodge motor with an nv4500 behind it... decided to p pump the old 1st gen... took 2 days and 3 cases of beer... runs worse than my old ve.... my timing is at 16* modded afc and fuel plate ground and foward... im thinkin bout goin back to my ve pump!!!! :sad:
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby Richie O » Mon Jan 05, 2009 6:33 pm
Put your head out side the window and you will here Dtanklage crying. :lol:
Postby peobryant » Mon Jan 05, 2009 7:11 pm
Did you drop the '94 motor in, or just use the pump off of it?
Postby peobryant » Mon Jan 05, 2009 7:26 pm
Also, what do you mean it is running bad? Can you explain more? It may be a simple issue that is causing it.
Postby TWorline » Mon Jan 05, 2009 7:44 pm
'91 Cummins wrote:Also, what do you mean it is running bad? Can you explain more? It may be a simple issue that is causing it.
What Parker said. Have you readjusted the pop pressure on your injectors to P-pump pressures? If not your timing is way advanced due to your injectors popping early if they are still set for a VE.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby railhor5.9 » Tue Jan 06, 2009 9:47 am
no i used the pump off the 94 motor and the injectors to... it dont run bad just not as good as my old ve... im sending it to scheid next week for a 5kgsk, cut dv's , and have it benched and tuned right...they said 600 with the right turbo... thinkin bout sum twins. :grin:
railhor5.9
Postby railhor5.9 » Tue Jan 06, 2009 9:50 am
hey congrats tworline for making it in diesel power... good lookin motor pic!!!
railhor5.9
Postby Philip » Tue Jan 06, 2009 10:10 am
Those 2nd gen injectors have the wrong spray angles for the pistons in a 1st gen. You need to change the tips to 1st gen tips.
Postby TWorline » Tue Jan 06, 2009 6:50 pm
railhor5.9 wrote:hey congrats tworline for making it in diesel power... good lookin motor pic!!!
Thank you!!! :grin:
Tim Worline
TWorline
Postby railhor5.9 » Wed Jan 07, 2009 11:09 am
how bad is it off??? it white smokes a lil... are the injector tips in the 1st gen bigger? o and another thing i used the p pump cam... then i was reading the specs on the cam and it said the lift on a first gen cam was 1.84 and the p pump has a 1.43 lift. plz tell me if u no if they diff. :sad:
railhor5.9
Postby peobryant » Mon Jan 12, 2009 6:34 pm
Did you ever get it figured out? Is it running right now?
Postby KTA » Tue Jan 13, 2009 11:37 am
Those cam numbers you are referring to sound like injection pump timing lifts. As for the actual engine cams a ic-d 1st gen is virtually identical to a 2nd gen automotive cam. The non ic motors have a little diffrent cam from the factory.
Postby pulltilbroke » Tue Jan 13, 2009 11:49 am
What is different about the N/IC cams Lift?Duration? LSA?
Postby KTA » Tue Jan 13, 2009 11:53 am
I do not know the exact diffrence because I have never degreed a non ic'd cam. I do know that they still retain a unique cummins part number while all the rest of the automotive cams sub to the same one. The only other 12V cam that exists is the marine cam which has more lift and duration since they were designed to make power at 3000rpm.
Re: regret p pumpin
Postby peobryant » Tue Jan 13, 2009 1:01 pm
railhor5.9 wrote:well i bought a 94 dodge motor with an nv4500 behind it... decided to p pump the old 1st gen... took 2 days and 3 cases of beer... runs worse than my old ve.... my timing is at 16* modded afc and fuel plate ground and foward... im thinkin bout goin back to my ve pump!!!! :sad:
A little off topic, but what are you going to do with that NV4500?
