1st gen Records?
Postby dpuckett » Wed Mar 19, 2008 8:10 pm
Each dyno will give diferent readings on the same day, same truck. May only be 1 or 2 hp, though. Throw in different atmospheric conditions, and it gets trickier to figure out who REALLY has the highest HP. Dave Dunbar has a mobile dyno that he pulls around to various events, so people from across the continent can have at least one constant variable in comparing hp/tq differneces between KY, CA, and BC.
Daniel
Postby 2muchtq » Wed Mar 19, 2008 8:16 pm
Stomps truck is nice... for a beat up farm truck.
2muchtq
Postby Begle1 » Wed Mar 19, 2008 11:35 pm
dpuckett wrote:Each dyno will give diferent readings on the same day, same truck. May only be 1 or 2 hp, though. Throw in different atmospheric conditions, and it gets trickier to figure out who REALLY has the highest HP. Dave Dunbar has a mobile dyno that he pulls around to various events, so people from across the continent can have at least one constant variable in comparing hp/tq differneces between KY, CA, and BC.
Daniel
So what it comes down to is "yeah, that makes a lot of power" and "yeah, that makes a lot of power too".
Postby KTA » Thu Mar 20, 2008 5:26 am
A dynojet measures acceleration to determine HP using F=MA. A Dyno Dynamics or Mustang are load dynos that measure torque to calculate HP. In my experinece the dynojet reads a bit lower especially in torque than the other 2 styles because it has turbo lag included in the run. The advantage to a dynojet is there are no loading variables to give diffrent results, also it does a better job of showing driveability. Many people complain they can't spool on a dynojet to make power, while that may be true it also means its a lag pig that would get spanked on the street.
Postby Cschafer » Thu Mar 20, 2008 11:07 am
i think that a load type dyno has more of a chance of being accurate to street driving if set up correctly but since it is a variable than the results can be very inconsistant. The new heavy wheight dyno jet should be a real good dyno for these trucks with drums at 8000lbs instead of 6000. I've ran a dyno jet alot and I have a application into a shop that has a mustang so hopefully I can figure out a load value that will make the numbers comparable to a 248c.
91 w250 wrecker
Cschafer
Postby GLHS » Thu Mar 20, 2008 8:48 pm
KTA wrote: Many people complain they can't spool on a dynojet to make power, while that may be true it also means its a lag pig that would get spanked on the street.
That makes me feel better. I usually can get just as much boost on Dynojets as I can on the street. I do hear a lot of people complain about that also.
I've been on 2 dynojets a few times and I always get the highest numbers on them; 2 Superflows usually about 10 hp less; Ats's Mustang is not generous what so ever when the correction is off.
GLHS
Postby pulltilbroke » Thu Dec 04, 2008 6:25 pm
What is the highest 12 mm hp
Postby GLHS » Fri Dec 05, 2008 9:23 am
Sounds like you have or are going to dyno?
I hope you do well no matter what Bill says. :D
Kta has done 488 uncorrected diesel only. I think he had twins and head work but that was 4.5 years ago when we were all trying to make 300 hp. :roll: I think he did 480 with a single.
Jayers has done 501 with a helix 2 cam I believe. Don't know what he had for turbo(s). Someone correct me if I'm wrong.
I have done 472 uncorrected diesel only, single charger, stock long block at 2600' elevation.
GLHS
Postby pulltilbroke » Fri Dec 05, 2008 6:49 pm
thanks GLHS
But I thought Jayers was on a 14 mm
I'm shootin for 500 on a 12mm then
Postby GLHS » Sat Dec 06, 2008 10:00 am
I have a feeling your shooting for way more than 500.
You may be right about the 501 run with a 14mm head.
GLHS
Postby pulltilbroke » Sat Dec 06, 2008 2:40 pm
Yeah I guess I am shootin for well over 500 but I'll try to hit 500 with my current pump 8)
Postby JAyers » Sun Dec 14, 2008 7:48 am
Yea guys it was a 14mm pump with a 62/71 S300.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby pulltilbroke » Thu Mar 05, 2009 1:13 am
KTA or Rockentech H&R?
Postby JAyers » Thu Mar 05, 2009 4:54 am
Rockentech
JAyers
Postby fourwheelininajeep » Thu Mar 05, 2009 8:18 am
I aint no dyno master but wouldnt difference in tire size also be a variable to consider. To be perfectly accurate, tires would be same size, gears would be the same ratio. Just a thought, if you guys are trying to compare apples to apples you got more like red apples and green apples. Same fruit but different in many characteristics.
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
fourwheelininajeep
