new era 370's
new era 370's
Postby Firstgen1 » Sun May 31, 2009 7:04 pm
does anybody run these injectors
what do you think, do they smoke like pod's
thanks :lol:
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby Richie O » Sun May 31, 2009 8:17 pm
Postby 2stroke » Mon Jun 01, 2009 4:58 pm
linky no worky?
91 non I/C w-350 SRW
2stroke
Postby Richie O » Mon Jun 01, 2009 5:11 pm
2stroke wrote:linky no worky?
It works for me. Sometimes photobucket is cranky on videos. Sometimes I have to hit refresh a couple of times to get it to load.
Postby PToombs » Mon Jun 01, 2009 5:56 pm
If I lug it in 5th and hammer it you can't see daylight for a few minutes. If I wind it a little before I shift I can drive as clean as it was stock. ;)
Postby Firstgen1 » Mon Jun 01, 2009 6:10 pm
sweet man how much power can they handle
Firstgen1
Postby PToombs » Mon Jun 01, 2009 6:27 pm
I got 388 hp on a dyno, and I don't think he loaded it enough. So it's someplace in that area.
Postby Firstgen1 » Thu Jun 04, 2009 1:50 pm
and these injectors just slap into our truck, i herd they are for the p-pump
Firstgen1
Postby PToombs » Thu Jun 04, 2009 5:50 pm
Depends on where you get them. 370's are a 2nd gen tip. You can get the tip and put them in 1st gen bodies, but the spray angle is wrong. If you get them from a reputable dealer, like New Era, it's a 1st gen tip EDM'd to a 370. Awesome injectors! 8)
