by fergavs » Fri May 29, 2009 6:26 pm
I don't remember exact numbers (can be found on another post) but my current non intercooled pump did over 400cc at 1600 stand rpm (3200 engine rpm) with the 14mm/4mm combo and 6-18's. Currently it makes well over 300cc of fuel at the same rpm and same injectors with the 14mm only.
I know I am making that kind of fuel because even with a 64mm turbo running 55psi, ported head, and cam I still couldnt control the egt's.
